  • LoRaWAN Certification update
    lopy lorawan
  • WiFi/Bluetooth antenna types
    hardware
    @jmarcelino seeing the results of the poll we will continue having both options available ;-)
  • Hackster.io Project Challenge!
    challenge hackster.io micropython
    Any chance Pytrack will be released in time for this challenge?
  • New firmware release 1.6.5.b1 (GC bug fixed)
    firmware
    6 Votes
    @daniel Thanks for the reply, I have installed the newest version, I'm using now the LoraWan nano gateway, my previous project was a lora gateway based on a raspberry pi and a LoPy board. The newest Firmware version include the Lorawan nano gateway example you have created with your team is Great!! Thanks!!! Another question: have you any idea when the newest Pytrack board is available? I have pre-order this and I can wait ;)
  • Q1 2017 development status
    firmware update
    @mcook Since version 1.6.4.b1 it's possible to call machine.deepsleep(number_of_ms) and the LoPy go into deep sleep in the way you want, however at the moment the current flow is still high (15mA@3.3v last time I checked) but this being investigated At the moment there's an issue with current not really dropping to just a few uA and we are investigating it. https://forum.pycom.io/topic/767/new-firmware-release-version-1-6-4-b1
  • New firmware release 1.6.6.b1
    firmware
    @daniel Any chance you will be able to update the source tree soon?
  • Which IDE do you use?
    Eclipse for all the coding languages I use
  • New firmware release, version 1.6.4.b1
    lopy wipy firmware sipy
    26
    6 Votes
    10k Views
    @daniel I see that some timings/stability improved in pin. Now i am able read samsung tv codes without any problem from python code without need of C function as previously :) I tested this i suppose in many previous versions (last tested lower than 1.5) and it was not stable enought but now it work :)
  • New firmware release, version 1.6.0.b1
    72
    41k Views
    @daniel - someone needs to reply to each issue posted by users, we are not mind readers !
  • Bugs/Issues moving to GitHub
    support ticketing bugs issues
    Ugh. Not everyone is willing to have a github account.
  • New updater tool released
    Thanks @Pete. We will add some redirects, the new link is: https://www.pycom.io/resources/
  • New firmware release, version 1.5.1.b1 (supporting the SiPy)
    24
    10k Views
    @daniel Marvelous News, thanks
  • SiPy is.... Sigfox READY!
    Hello, A quick announcement to let you know that we have been working late nights the entire week to get the flashing and activation mechanism for the SiPy ready. We were hoping to get this out by Friday, and we managed to finish everything, but we wanted to test it a bit more over the weekend. The good news is that it will be released for sure on Monday (finally!). Cheers, Daniel
  • New firmware release 1.5.0.b2
    29
    10k Views
    @jmarcelino @livius I'm working on this as we speak. Will update you shortly.
  • New firmware release 1.4.0.b1
    65
    41k Views
    @Colateral bus = I2C(0, I2C.MASTER, baudrate=100000, pins=("P19", "P20")) return: b'U\x02' print(ubinascii.hexlify(bus.readfrom_mem(119, 0xD0, 1))) b'55' print(ubinascii.hexlify(bus.readfrom_mem(119, 0xD0, 2))) b'5502' and chip revision: >>> print(ubinascii.hexlify(bus.readfrom_mem(119,0xd1, 2))) b'0206' it looks ok 550206
  • New firmware release 1.5.0.b1 and SiPy Sigfox certification completed
    21
    8k Views
    @mohpor There was no open issue on Github for this problem and to me changing a 2 to 3 didn't seem to warrant opening a PR so I simply brought it up on the forum, seemed to be most practical way of addressing this.
  • Weekly update W/C 16th Jan 2017
    @daniel Thank you. Great :o)
  • IoT Tech Expo - 23-25 Jan 2017
  • Firmware release 1.1.0.b1
    32
    5 Votes
    12k Views
    @bmarkus It can be a LoRaWAN nano gateway listening to one channel at a time. Be mindful that this is not LoRaWAN compliant but is very useful in certain conditions. We will release the full firmware with this functionality early Feb.
  • LoPy LoRaWAN™ Certified
    @bmarkus The version that has being certified is 1.0.0 which will have the LoRa stack locked. The current version on the modules are Beta. We will release the latest firmware shortly. Thanks Fred
