• Video over WiFi
    wipy lopy video camera wifi
    @sthomson No. i have played videos over wifi. I will try to stream video over wifi from one wipy to another and will let you know.
  • Guru Meditation Error - Pycom WiPy
    wipy coredump bug
    35
    Dear @Milan and @Martinnn, if you feel lucky, you might want to try our custom build just released on [1]. More background about this is available through [2]. Please be aware that you will have to erase your device completely before flashing in order to keep things straight. You will find respective references to this on the forum. Hint: Use pycom-fwtool-cli --port /dev/ttyUSB0 erase_all, see also [3]. With kind regards, Andreas. [1] https://packages.hiveeyes.org/hiveeyes/foss/pycom/vanilla/WiPy-1.20.1.r1-0.6.0-vanilla-dragonfly.tar.gz [2] https://community.hiveeyes.org/t/investigating-random-core-panics-on-pycom-esp32-devices/2480 [3] https://community.hiveeyes.org/t/installing-the-recent-pycom-firmware-1-20-1-r1-requires-erasing-the-flash-memory-completely/2688
  • Damaged WiPy 3.0
    @EngeenerAtendee From menuconfig did you change the flashing port ? In the esp-idf it is set to /dev/ttyUSB0. Can you download the the Pycom firmware updater and do an erase all from the cli ? Then try to re-flash using the Pycom updater.
  • Multiple SPI devices WiPy 3.0
    @EngeenerAtendee Each device should have a CS input, which must be pulled low to activate it. You can share SCLK, MOSI and MISO for all three devices, and have to pull CS low for the one that is to be used. So you need 6 GPIO ports.
  • ADC - What is the maximum voltage value possible to measure?
    @dabal221 Please read here The maximum is 3.3v at an attenuation of 11db. Please calibrate the ADC before usage.
  • Sending data from WiPy to the SQL database on Raspberry Pi
    Laravel Webserver on raspberry ??
  • Working with UUID
    @jmarcelino said in Working with UUID: For some reason I've not yet understood the bytes also have to be in reverse order of how you'd type them. Dear @jmarcelino, coming from [1], we have been able to shed some light onto the background of the byte-swapping of UUIDs within some Bluetooth stacks around and wrapped it up at [2] by a) reusing your uuid2bytes from above and b) complementing it with the inverted function. With kind regards, Andreas. [1] https://forum.pycom.io/topic/5335/ble-decoding-service-uuid [2] https://github.com/hiveeyes/hiveeyes-micropython-firmware/blob/a8249fd8e9895623de8047ca2d6478dba1351aa8/terkin/network/ble/util.py
  • I2C pin
    @ciccio An i2c master can be connected to multiple slave devices. Please read this artice. Please however notice that the pycom devices can be configure as master only
  • BLE scan between pycoms
    @mdelhorno Please can you send you full code to support@pycom.io . The code below is working for me: from network import Bluetooth import utime bluetooth = Bluetooth() bluetooth.set_advertisement(name='Module_1', service_uuid=b'1234567890123456') bluetooth.advertise(True) bluetooth.start_scan(-1) # start scanning with no timeout while True: print(bluetooth.get_adv()) utime.sleep(0.2)
  • Why MicroWebSrv not runnning on Wipy3.0 ?
    microwebsrv wipy3.0 micropython network
    Hello, If you want, I propose a new powerful embedded Web Server for MicroPython (and CPython) that supports route handlers, modules like WebSockets or PyhtmlTemplate and a lot of simultaneous requests. Mostly used on ESP32, Pycom WiPy, STM32 on Pyboard, ... Robust and efficient (thousands requests on CPython!) GitHub - Open Source - MIT. --> https://github.com/jczic/MicroWebSrv2 <--
  • WiPy 2.0 Captive Portal Network Config
    captive portal wipy 2.0 dhcp dns ap mode
    Hello, I released a fully new version (v2.0) of my web server here : https://github.com/jczic/MicroWebSrv2. Open source MIT, fully asynchronous, more robust, more fast and more efficient on Pycom modules. It is delivered with a good documentation. For captive portal, you can use a simple DNS server here (see readme) : https://github.com/jczic/MicroDNSSrv Thank you for your support and feedback. ☺️
  • WEB Server
    29
    13k Views
    Hello, I released a fully new version (v2.0) of my web server here : https://github.com/jczic/MicroWebSrv2. Open source MIT, fully asynchronous, more robust, more fast and more efficient on Pycom modules. It is delivered with a good documentation. Thank you for your support and feedback. ☺️
  • Reread Setting.py while the program is running.
    wipy lopy import
    @robert-hh That's how it works perfectly! Thank you very much. import sys del sys.modules['settings'] time.sleep(1) import settings
  • Waveshare 4.2b e-Ink, libraries not working?
    eink
    @Peter-Ehses i had a wavershare 4.2 b/w display in the drawer which I never used. Now I grabbed that and tested it with mcauser's lib. It worked immediately. I used a ESP32, like WiPy3, with the micropython.org firmware.
  • No console output in PyMakr whatsoever
    techykermitT
    @robert-hh I removed the os module and now everything seems to work fine. Thank you so much for actually taking time and helping out :))
  • Cannot update firmware on W01
    Well, issue seems to be resolved! It looks like our new design had P8 pulled HIGH. According to this pycom ticket: https://github.com/pycom/pycom-documentation/issues/96 this will cause the firmware upgrade to have issues.... We removed the pullup from P8 (we are using it for another purpose).. and now are able to talk to the ext flash and update the firmware. Maybe this should be more clear in the pycom documentation?
  • Online Update?
    wipy lopy update upgrade
    @robert-hh Thank you
  • Cant connect to the WiPy3.0 at all, even in safe boot
    @Joaquim-Vieira Are you sure it is COM4? You can verify by opening the device manager and plugging & unplugging your device. The COM port in questions should appera and disappear in the com sections of the devices.
  • Wipy setup via iphone pymate app not connecting
    setup
    Look facing issue in pymate App connection in iPhone before solving it Fix iTunes Error 9 occurred, still, visit here https://itunessupport.org/blog/fix-itunes-error-9/ need to fix Error 9. how can I fix it?
