I made those changes and worked thru a few more issues.
I get output the first time thru then it breaks. Still working through that but here's what I've got so far
Serial output:
[41, 64]
[41, 64]
[41, 64]
[41, 64]
[41, 64]
Total light: 55.55328lux
[41, 64]
[41, 64]
Infrared light: 141
[41, 64]
[41, 64]
Visible light: 9241007
[41, 64]
[41, 64]
Full spectrum (IR + visible) light: 9241149
[41, 64]
[41, 64]
Total light: 0.0lux
[41, 64]
[41, 64]
Infrared light: 0
[41, 64]
[41, 64]
Visible light: 0
[41, 64]
[41, 64]
Full spectrum (IR + visible) light: 0
the zero outputs repeat the rest of the tries.
tsl2591.py:
# The MIT License (MIT)
# Copyright (c) 2017 Tony DiCola for Adafruit Industries
# Permission is hereby granted, free of charge, to any person obtaining a copy
# of this software and associated documentation files (the "Software"), to deal
# in the Software without restriction, including without limitation the rights
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
# copies of the Software, and to permit persons to whom the Software is
# furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
# THE SOFTWARE.
`adafruit_tsl2591`
CircuitPython module for the TSL2591 precision light sensor. See
examples/simpletest.py for a demo of the usage.
* Author(s): Tony DiCola
Implementation Notes
**Hardware:**
* Adafruit `TSL2591 High Dynamic Range Digital Light Sensor
<https://www.adafruit.com/product/1980>`_ (Product ID: 1980)
**Software and Dependencies:**
* Adafruit CircuitPython firmware for the ESP8622 and M0-based boards:
https://github.com/adafruit/circuitpython/releases
* Adafruit's Bus Device library: https://github.com/adafruit/Adafruit_CircuitPython_BusDevice
from micropython import const
#import adafruit_bus_device.i2c_device as i2c_device
from machine import I2C,Pin
#__version__ = "0.0.0-auto.0"
#__repo__ = "https://github.com/adafruit/Adafruit_CircuitPython_TSL2591.git"
#pylint: disable=bad-whitespace
# Internal constants:
_TSL2591_ADDR = const(0x29)
_TSL2591_COMMAND_BIT = const(0xA0)
_TSL2591_ENABLE_POWEROFF = const(0x00)
_TSL2591_ENABLE_POWERON = const(0x01)
_TSL2591_ENABLE_AEN = const(0x02)
_TSL2591_ENABLE_AIEN = const(0x10)
_TSL2591_ENABLE_NPIEN = const(0x80)
_TSL2591_REGISTER_ENABLE = const(0x00)
_TSL2591_REGISTER_CONTROL = const(0x01)
_TSL2591_REGISTER_DEVICE_ID = const(0x12)
_TSL2591_REGISTER_CHAN0_LOW = const(0x14)
_TSL2591_REGISTER_CHAN1_LOW = const(0x16)
_TSL2591_LUX_DF = 408.0
_TSL2591_LUX_COEFB = 1.64
_TSL2591_LUX_COEFC = 0.59
_TSL2591_LUX_COEFD = 0.86
_TSL2591_MAX_COUNT_100MS = const(36863) # 0x8FFF
_TSL2591_MAX_COUNT = const(65535) # 0xFFFF
# User-facing constants:
GAIN_LOW = 0x00 # low gain (1x)
"""Low gain (1x)"""
GAIN_MED = 0x10 # medium gain (25x)
"""Medium gain (25x)"""
GAIN_HIGH = 0x20 # medium gain (428x)
"""High gain (428x)"""
GAIN_MAX = 0x30 # max gain (9876x)
"""Max gain (9876x)"""
INTEGRATIONTIME_100MS = 0x00 # 100 millis
"""100 millis"""
INTEGRATIONTIME_200MS = 0x01 # 200 millis
"""200 millis"""
INTEGRATIONTIME_300MS = 0x02 # 300 millis
"""300 millis"""
INTEGRATIONTIME_400MS = 0x03 # 400 millis
"""400 millis"""
INTEGRATIONTIME_500MS = 0x04 # 500 millis
"""500 millis"""
INTEGRATIONTIME_600MS = 0x05 # 600 millis
"""600 millis"""
#pylint: enable=bad-whitespace
class TSL2591:
"""TSL2591 high precision light sensor.
:param busio.I2C i2c: The I2C bus connected to the sensor
:param int address: The I2C address of the sensor. If not specified
the sensor default will be used.
# Class-level buffer to reduce memory usage and allocations.
# Note this is NOT thread-safe or re-entrant by design.
_BUFFER = bytearray(2)
def __init__(self, i2c, address=_TSL2591_ADDR):
self._integration_time = 0
self._gain = 0
self.i2c=i2c#I2C(pins=("P9","P10"))
self._i2c_address=address
#self._device = i2c_device.I2CDevice(i2c, address)
# Verify the chip ID.
if self._read_u8(_TSL2591_REGISTER_DEVICE_ID) != 0x50:
raise RuntimeError('Failed to find TSL2591, check wiring!')
# Set default gain and integration times.
self.gain = GAIN_MED
self.integration_time = INTEGRATIONTIME_100MS
# Put the device in a powered on state after initialization.
self.enable()
def _read_u8(self, address):
# Read an 8-bit unsigned value from the specified 8-bit address.
#with self._device as i2c:
# Make sure to add command bit to read request.
#self._BUFFER[0] = (_TSL2591_COMMAND_BIT | address) & 0xFF
# self.i2c.writeto(self._BUFFER, end=1, stop=False)
#self.i2c.writeto(_TSL2591_ADDR,self._BUFFER)
#self.i2c.readinto(self._BUFFER, end=1)
print(self.i2c.scan())
self.i2c.readfrom_mem_into(self._i2c_address,(_TSL2591_COMMAND_BIT|address) & 0xFF,self._BUFFER)
return self._BUFFER[0]
# Disable invalid name check since pylint isn't smart enough to know LE
# is an abbreviation for little-endian.
#pylint: disable=invalid-name
def _read_u16LE(self, address):
# Read a 16-bit little-endian unsigned value from the specified 8-bit
# address.
#self.i2c.write(self._BUFFER, end=1, stop=False)
#self.i2c.readinto(self._BUFFER, end=2)
return (self._BUFFER[1] << 8) | self._BUFFER[0]
#pylint: enable=invalid-name
def _write_u8(self, address, val):
# Write an 8-bit unsigned value to the specified 8-bit address.
# Make sure to add command bit to write request.
#self._BUFFER[1] = val & 0xFF
#self.i2c.write(self._BUFFER, end=2)
self.i2c.writeto_mem(self._i2c_address,(_TSL2591_COMMAND_BIT | address) & 0xFF,val & 0xFF)
def enable(self):
"""Put the device in a fully powered enabled mode."""
self._write_u8(_TSL2591_REGISTER_ENABLE, _TSL2591_ENABLE_POWERON | \
_TSL2591_ENABLE_AEN | _TSL2591_ENABLE_AIEN | \
_TSL2591_ENABLE_NPIEN)
def disable(self):
"""Disable the device and go into low power mode."""
self._write_u8(_TSL2591_REGISTER_ENABLE, _TSL2591_ENABLE_POWEROFF)
@property
def gain(self):
"""Get and set the gain of the sensor. Can be a value of:
- ``GAIN_LOW`` (1x)
- ``GAIN_MED`` (25x)
- ``GAIN_HIGH`` (428x)
- ``GAIN_MAX`` (9876x)
control = self._read_u8(_TSL2591_REGISTER_CONTROL)
return control & 0b00110000
@gain.setter
def gain(self, val):
assert val in (GAIN_LOW, GAIN_MED, GAIN_HIGH, GAIN_MAX)
# Set appropriate gain value.
control &= 0b11001111
control |= val
self._write_u8(_TSL2591_REGISTER_CONTROL, control)
# Keep track of gain for future lux calculations.
self._gain = val
@property
def integration_time(self):
"""Get and set the integration time of the sensor. Can be a value of:
- ``INTEGRATIONTIME_100MS`` (100 millis)
- ``INTEGRATIONTIME_200MS`` (200 millis)
- ``INTEGRATIONTIME_300MS`` (300 millis)
- ``INTEGRATIONTIME_400MS`` (400 millis)
- ``INTEGRATIONTIME_500MS`` (500 millis)
- ``INTEGRATIONTIME_600MS`` (600 millis)
return control & 0b00000111
@integration_time.setter
def integration_time(self, val):
assert 0 <= val <= 5
# Set control bits appropriately.
control &= 0b11111000
control |= val
# Keep track of integration time for future reading delay times.
self._integration_time = val
@property
def raw_luminosity(self):
"""Read the raw luminosity from the sensor (both IR + visible and IR
only channels) and return a 2-tuple of those values. The first value
is IR + visible luminosity (channel 0) and the second is the IR only
(channel 1). Both values are 16-bit unsigned numbers (0-65535).
# Read both the luminosity channels.
channel_0 = self._read_u16LE(_TSL2591_REGISTER_CHAN0_LOW)
channel_1 = self._read_u16LE(_TSL2591_REGISTER_CHAN1_LOW)
return (channel_0, channel_1)
@property
def full_spectrum(self):
"""Read the full spectrum (IR + visible) light and return its value
as a 32-bit unsigned number.
channel_0, channel_1 = self.raw_luminosity
return (channel_1 << 16) | channel_0
@property
def infrared(self):
"""Read the infrared light and return its value as a 16-bit unsigned number.
_, channel_1 = self.raw_luminosity
return channel_1
@property
def visible(self):
"""Read the visible light and return its value as a 32-bit unsigned number.
full = (channel_1 << 16) | channel_0
return full - channel_1
@property
def lux(self):
"""Read the sensor and calculate a lux value from both its infrared
and visible light channels.
# Compute the atime in milliseconds
atime = 100.0 * self._integration_time + 100.0
# Set the maximum sensor counts based on the integration time (atime) setting
if self._integration_time == INTEGRATIONTIME_100MS:
max_counts = _TSL2591_MAX_COUNT_100MS
else:
# Handle overflow.
if channel_0 >= max_counts or channel_1 >= max_counts:
raise RuntimeError('Overflow reading light channels!')
# Calculate lux using same equation as Arduino library:
# https://github.com/adafruit/Adafruit_TSL2591_Library/blob/master/Adafruit_TSL2591.cpp
again = 1.0
if self._gain == GAIN_MED:
again = 25.0
elif self._gain == GAIN_HIGH:
again = 428.0
elif self._gain == GAIN_MAX:
again = 9876.0
cpl = (atime * again) / _TSL2591_LUX_DF
lux1 = (channel_0 - (_TSL2591_LUX_COEFB * channel_1)) / cpl
lux2 = ((_TSL2591_LUX_COEFC * channel_0) - (_TSL2591_LUX_COEFD * channel_1)) / cpl
return max(lux1, lux2)
main.py:
# Simple demo of the TSL2591 sensor. Will print the detected light value
# every second.
import time
from machine import I2C, Pin #added for tsl2591 sensor
#import board
#import busio
import tsl2591
#i2c = I2C(0, pins=("P9","P10"))
# Initialize the I2C bus.
i2c = I2C(0,pins=("P9","P10"))#board.SCL, board.SDA)
#i2c=i2c
i2c.init(I2C.MASTER, baudrate=9600)
# Initialize the sensor.
sensor = tsl2591.TSL2591(i2c)
# You can optionally change the gain and integration time:
#sensor.gain = adafruit_tsl2591.GAIN_LOW (1x gain)
#sensor.gain = adafruit_tsl2591.GAIN_MED (25x gain, the default)
#sensor.gain = adafruit_tsl2591.GAIN_HIGH (428x gain)
#sensor.gain = adafruit_tsl2591.GAIN_MAX (9876x gain)
#sensor.integration_time = adafruit_tsl2591.INTEGRATIONTIME_100MS (100ms, default)
#sensor.integration_time = adafruit_tsl2591.INTEGRATIONTIME_200MS (200ms)
#sensor.integration_time = adafruit_tsl2591.INTEGRATIONTIME_300MS (300ms)
#sensor.integration_time = adafruit_tsl2591.INTEGRATIONTIME_400MS (400ms)
#sensor.integration_time = adafruit_tsl2591.INTEGRATIONTIME_500MS (500ms)
#sensor.integration_time = adafruit_tsl2591.INTEGRATIONTIME_600MS (600ms)
# Read the total lux, IR, and visible light levels and print it every second.
while True:
# Read and calculate the light level in lux.
lux = sensor.lux
print('Total light: {0}lux'.format(lux))
# You can also read the raw infrared and visible light levels.
# These are unsigned, the higher the number the more light of that type.
# There are no units like lux.
# Infrared levels range from 0-65535 (16-bit)
infrared = sensor.infrared
print('Infrared light: {0}'.format(infrared))
# Visible-only levels range from 0-2147483647 (32-bit)
visible = sensor.visible
print('Visible light: {0}'.format(visible))
# Full spectrum (visible + IR) also range from 0-2147483647 (32-bit)
full_spectrum = sensor.full_spectrum
print('Full spectrum (IR + visible) light: {0}'.format(full_spectrum))
time.sleep(1.0)
