• Pysense looses connection to wipy - wipy reset
    pysense wipy2.0 error hardware reset
    Can you please first try another firmware update (we have released 1.10.2.b1). If that doesn't help please try to format the internal flash: import os; os.mkfs('/flash') If that still doesn't help please email support@pycom.io
  • Pytrack board not detected error when using soft reboot (ctrl-C)
    lopy pytrack
    Nagarjuna ReddyN
    @ozeta hiiiii friends your problem like your application is not stop run again continuously i mean right in their one solution you have taken one jumper wire put it on your board 3v3 and G28 then orange led is blinking than you remove your jumper wire. here current execute method is stopped (main.py) .
    catalinC
    Regarding the light sensor (LTR-329ALS), my understanding was that it LTR329ALS01.light() gives the 2 numbers representing the lux values of 2 channels. If you left the default configuration registers (Gain 1x-> 1lux to 64k lux) then the lux values are exact the values returned. The 2 channels have a different sensitivity based on wavelength (ch0 ~450nm violet-blue and ch1 ~770nm red). I don't know what's raw2lux. Also the ratio d1/(d1+d0), is mentioned in datasheet but I did not understood the meaning. I've read the datasheet from: http://optoelectronics.liteon.com/upload/download/DS86-2014-0006/LTR-329ALS-01_DS_V1.pdf On my desk, evening, I have: '>>> lt = LTR329ALS01(py) '>>> print("Light: " + str(lt.light())) 'Light: (45, 33) 45 lux, 1.5m away (surface is sphere with 1.5m radius) -> 1272 lm, seems ok, as I have 3 bulb-lights of ~400lm. But with cellphone, 2 cm away: Light (6617, 2758) <Later edit> I've used this online tool to convert lux to lumens, as light-bulbs have specs in lumens http://www.rapidtables.com/calc/light/lux-to-lumen-calculator.htm Also with a Blue+Green LED, I've obtained values (85,7), which indicates a blue light, and lack of red light.
  • IP67 Case for Pysense/Pytrack
    ip67 pytrack lo
    @sysfrog If you are using pysense/pytrack, you dont need the deepsleep shield
    I am using the expansion board 2.0. I have no deep sleep shield yet (Pycom forgot to send the deep sleep shield with the order of the lopy 2 weeks ago. They told me a deep sleep shield is on its way now) We deinit the WLAN from start because we don't use it. We charge just using the micro-usb cable. It is configured with the jumpers at 450mA charge current. In the battery test we did, we intentionally drained the battery fully to see how long it would last. We expected the LoPy to stop working eventually, but expected we would be able to recharge it using the USB connection at that point. Can the deep sleep shield -if used on the LoPy 1- recharge a drained battery by just plugging the USB-cable in after the battery was exhausted and shut off by the deep sleep shield?
  • [SOLVED] broken Pysense board?
    pysense wipy2 i2c expansion board error
    @jorismathijssen Hi Joris. Did you tried tot upload thé firmware again? Be sure to powercycle your device. Did you run dfu utils with elevated rights? (Admin on Windows of sudoku on Linux?) Good luck
  • Pysense pressure/Altitude odd readings
    lopy pysense mpl3115a2
    I found out that like below, the results are plausible. No clue why the above mentioned way does not work, but at least this is a workaround. [image: 1508350679444-image.png]
    @gmaitre The 3.3 V output can supply up to 1 A current, so supplying a DHT22 and GPS module should not be a problem. The PyTrack board has an additional connector on the bottom, with some GPIO pins exposed, for instance P10 (G17) and P11 (G22). These could be used to connect the DHT22.
  • High GPIO Pins
    pin gpio sipy
    @bradnz So you want to tell, if the voltage of the LiPo battery is above 2.5 V. That should be done using the ADC, for various reasons. a) The value at which a digital input switches from HIGH to LOW is not well defined and not stable. It is somewhere between 0.75 * Vdd and 0.25 * Vdd b) You have to check the value of the variable charger anyhow, so instead of doing that you could also read an ADC value. If you want to have that done in an interrupt fashion, you can set-up a timer interrup which reads the ADC,
  • Power consumption on Pytrack with SiPy
    gps pytrack accelerometer power saving
    joeriJ
    @asaph I've tried it out and it works fantastically 🎉 Thanks @Daniel!
  • Maximum battery voltage?
    battery lipo
    Many thanks!
  • Deep Sleep Shield: Persistent low voltage limit
    deep sleep
  • Pytrack RMC message
    pytrack gnrmc
    @urblau said in Pytrack RMC message: gc.mem_free() <= 25000 why do you reset device under 25K free mem? And you should analyze where you consume memory. My pytrack work many days and collect and then send data to the server. You must carefully manage strings and make calculations. e.g. previously i have used some implementation from internet about HMC5883L but when i saw how it eat memory on every run i go into optimized solution. maybe this point you to some direction: https://github.com/pycom/pycom-libraries/pull/8/files sometimes python syntax is evil in limited memory world..
  • GPS antenna pattern
    gps antenna pytrack
    Thank you for the links, but the antenna is external (on the PyTrack) so the datasheets do not contain any info about the antenna pattern.
  • Pytrack Gps not working?
    l76lgnss pytrack nmea
    Hi! Any progress? I seem to have the same issue. Thanks! Marco
  • PySense & PyTrack incompatibilities?
    pytrack pysense document
    @jcaron I made another round in the documentation. It would be "nice" if Pycom would REMOVE outdated information or have links directed to one place with the latest documentation. Indeed when searching again: https://pycom.io/wp-content/uploads/2017/04/pysensePinoutCompN3.pdf https://docs.pycom.io/chapter/datasheets/boards/pysense.html So PLEASE Pycom get old documentation from your official website! And release the schematics of the PyTrack and PySense and the mystery around the PIC chip. After all I think your business is the selling of the modules, not the accessories that show how they can be used?!
  • Button on pytrack/pysense
    pysense pytrack sche
    @Emmanuel-Goudot I sincerely hope Pycom will release the schematics. I have asked them a few times now and no response. IMHO This will do more harm than good for Pycom. It is not rocket science and it is crazy I see so many posts on people trying to reverse engineer the board(s) and even patch the firmware of the PIC by hand? The documentation is not complete or different depending on what file you read. To much time is already spend on finding out all the connections and how it works and even then it is not sure if it is correct or what side effects are possible. PYCOM: let us help you, there is a big community of enthusiastic users that can help you forward. I just finished comparing pysense/track/lopy wiring diagrams to find out which pins can be used.
  • is short period Deep Sleep possible to save power?
    power saving pytrack sipy
    @chrisi Or what about good old UART?
    When working with unprotected cells, a circuit like this should work fine, right? [image: 20170825235011-yimzrv24.png] With a MAX6430EGUS+T, the ~LBOH output turns low when battery voltage is <3.3V, while ~LBOL turns low when battery voltage is <3.0V. That should trigger the left MOSFET and turn off the entire circuit.
    @robert-hh Thanks. it is working with 115200.
