• no data in line chart
    pybytes
    @jirkakrepl today there is no data displayed the last samples are from 3 days ago. if i have a pull size of 20 it says no recent data. the best thing for me with those line graphs is to select the time scale and it plots al the data points in between.
  • measurement of the accelerometer?
    @gaconvn1106 said in measurement of the accelerometer?: What is the unit of output of the acclerometer? is it m/s^2 of mm/s^2 or something else? It is in g (gravity)
  • How To Fix connection failed with error 651 with Netgear Routers?
    Hi @steverogger007, you mean you can't access http://pybytes.pycom.io on your phone, please?
    @dnear1 We deployed the fix now
  • Pybytes Terminal shows data out of order
    terminal pybytes lopy4
    Ive pointed the correct people at this thread. one of them should be able to answer soon :)
  • FiPy. Setting device: NBIoT network not available
    nbiot fipy spain
    @robert-hh Hi, we don't officially support nb-iot in Pybytes yet. But it's on our roadmap for this year.
  • Stubborn Wifi name... want the defaults...
    pybytes lopy4
    Just got around to getting back to this issue - thanks so much Xykon, problem solved! robert-hh: I did do erase during update yep, a few times, but eventually was solved with advice from the post above :)
  • Factory Reset Pysense + Fipy
    fipy firmware pysense update failed
    @jazzyhawk Hey, try doing a safeboot. It should skip your boot.py and main.py code and allow you back in. https://docs.pycom.io/gettingstarted/programming/safeboot.html
  • Can't connect FiPy via LoRa
    pybytes lora lorawan lorawan otaa otaa
    @weingami Hi, I deployed hotfix and tested wifi, sigfox and lora connections. I correctly received the data. We need to test more things and there are a few more bugs, that we know and we're about to fix now.
  • wlan.isconnected() in AP mode - still not working
    isconnected ap mode wlan
    @mfalkvidd, @Paul-Thornton thank you for taking care of this! I am looking forward to a solution as soon as possible. Not only my project strongly depends on this function as it is a rather basic functionality. At least, I could not find any alternative way of detecting connected devices in AP mode.
  • expansion board 3.0 not recognized pro windows 10 pro
    eduinaf1980
    I have had this issue a couple of times with different boards (just today in fact). To solve I upgraded the firmware on the expansion board 3.0.
  • Pybytes not being updated
    pybytes
    @cirobr glad that got it fixed for you. Not sure if it was a case of overload. More just having time to develop rate limiting that never existed previously.
  • Verizon LTE-CATM1 FiPy + Pytrack
    verizon fipy lte m1
    @wghirakawa Related to a different question (https://forum.pycom.io/topic/4118/gpy-or-fipy-using-lte-in-the-us), could I please ask you to check the result of 'AT+SQNHPLMN?'. I am trying to find out if Sequans supports 6-digit PLMNs in the US.
  • PyBytes Location Source
    fipy gps pytrack pybytes location
    @protean Hi, when you click on "get location button", Device scans the wifi networks around and sends the result to Pybytes. Pybytes is using Google location API to figure out and the location.
  • lorawan nanogateway pytrack gps
    pytrack fipy nano gateway
    @rcolistete thank you for the pointer I have tried and no problems so far I'll give it a couple of days before sending it to the wild :)
  • wifi via Atom
    atom wifi non usb develop
    @kjm I have used Atom over wifi. Had 8 pumps with GPY installed in a large workshop that the pycoms needed upgrading. So rather than have someone take a laptop to each device (I was on the other side of the country) they set the laptop up on ethernet, I team viewered in and connecting to each GPY over wifi from Atom. Worked fine.
  • JSON posts
    requests urequests micropython
    @kjm Line 52 doesn't seem to be related to datapayload, so i suppose that data = ujson.dumps({"post_wrapper":payload})) do the work. I don't know what OSError 128 mean but the line seem to be related to networking. Does your software have do correctly the connect with your wifi hotspot before trying to send your request ?
  • Atom foibles.
    atom gpy repl
    @kjm But maybe since we are mentioning it... someone who already has a fix can pass it along. Or someone who didn't realize it was a problem can make the next version a little bit better. Hopefully shared misery will have a shared cure. ;)
