• Is 5V necessary?
    power
    You rock.
  • Updating firmware for V1.0 board
    wipy 1 firmware update
    @Bryan Hello Bryan, you also asked on the micropython.org board, which is the right forum for your problem. I placed an answer there, which may fix your issue.
  • What is the difference between Pin.IN and Pin.OPEN_DRAIN?
    pin
    @BetterAuto When set to Pin.IN, the pin can be used for input only. changing the output value does not affect it's state. A pin declared as Pin.OPEN_DRAIN can be used for input AND output, but needs an Pull-Up resistor for a high value. When set to high, the output stage does not drive the pin any more, and the input value can be read, if that is driven by the peripheral. It's a of wired or for the low value. This method is used e.g. by I2C.
  • SD card on different pins
    sdcard wipy 2
    @jmarcelino Thank you for detailed answer
  • How to RS232? (MaxSonar MB7360 ultrasonic sensor)
    wipy2.0 help rs232
    @tobz https://www.sparkfun.com/products/11189 Or one of the many others (look for MAX3232 on Aliexpress or EBay for example)
  • Bluetooth WiPy client connecting to WiPy peripheral
    bluetooth
    Hello, Thanks for pointing out this bug. It has been fixed on the latest release 1.7.1.b1. Cheers, Daniel
  • Connect and send data via WiFi from WiPy to LoPy
    wipy wify lopy
    @amartinez for server node it is not good to have while not wlan.isconnected(): time.sleep_ms(50) You do not connect wifi here only you start Access Point (AP) - look if it start on network list scan on client node side or your PC
  • UART MAX485 Module
    wipy uart rs485
    Hello, any update on this? I have some old modbus plc lying around and i'm trying to use my lopy to communicate as a modbus master with a SP3485 breakout board...but i cannot find a decent modbus library for micropython
  • Read Tx Power from a iBeacon Device with Wipy2
    ble bluetooth ibeacon txpower rssi
    @pwest We've found out how. On iBeacon, when you read the data you get an Array. You need to do int(lastHexValue, 16) and then -256. This results in the set TxPower the BLE Beacon has Edit: this site explains very well how the iBeacon protocoll is built, aswell as to where to find the TxPower: http://www.warski.org/blog/2014/01/how-ibeacons-work/
  • Can't edit/change files
    wipy2.0 firmware filesystem
    I managed to find a USB-to-serial adapter and tried some things with that. My Windows machine won't recognize it, and on my mac I can't figure out what tty port it's on. I did however dig out a Raspberry Pi where it seem to work. Unfortunately it didn't help, because the linux-version of the pycom updater just keeps saying "Something failed trying to connect to the device." and then gives no further info. I also tried modifying the baud rate in the updater.py script as some thread suggested, but no luck.
    tobzT
    Ah derp. yeah that works. I'm new to (micro)python & coding for hardware, so learning lots at the moment. Thanks.
  • WiPy go to sleep and don't wake up on ftp or telnet connexions
    @Brunus Did you try to set a long server timeout with server.timeout(86400) Which for instance will set the timeout to a full day.
    @Arkaik classic way always work ;-)
  • Cannot connect to WiPy 2.0 via USB
    usb wipy2.0 expansionboard
    Solved! These are the right drivers to install! http://www.ftdichip.com/Drivers/D2XX.htm
  • 'Timer' has no attribute 'PERIODIC'
    wipy2.0 timer irq interrupt periodic
    Hi @bucknall, I finally found this library for using queues on micropython. However, this library need collections.deque and uasynio.core. 1 from collections.deque import deque 2 from uasyncio.core import sleep I went to the github repository, I downloaded collection.deque but I couldn't find uasynio.core anywhere. I think I'm not importing libraries correctly because I need to modify the line from collections.deque import deque to from collections import deque So now I would like to find the uasyncio.core module to be able to use the queue library ^^ I hope I do not need to open a new thread for this question. If so, I'm sorry ;)
  • Send data WiPy to LoPy via BLE
    ble wipy lopy
    Hi @amartinez, There's a really good explanation about GATT (Generic Attribute Profile) here - https://learn.adafruit.com/introduction-to-bluetooth-low-energy/gatt Currently BLE is the protocol available but classic Bluetooth will be coming in the future! Thanks!
    @tenspot No problem! :) It was likely that you had a very old version of the firmware tool installed!
  • Interfacing to the I2C bus on the WiPy 2.0
    wipy i2c
    Tidied things up a bit and added some constants to make it 'easier' to see what is going on, may get round to writing a module to for the MCP23017. Any guidance on what the interfaces should look like any where would be useful..? #!/usr/bin/python # # This program is free software: you can redistribute it and/or modify it # under the terms of the GNU General Public License as published by the Free # Software Foundation, either version 3 of the License, or (at your option) # any later version. # # This program is distributed in the hope that it will be useful, but # WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY # or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License # for more details. # # You should have received a copy of the GNU General Public License along # with this program. If not, see <http://www.gnu.org/licenses/> # I2CBUS = 0x00 # I2C bus number (Always 0 on WiPy) ADDRESS = 0x20 # I2C address of I/O expander. IODIRA = 0x00 # Port A data direction register. IODIRB = 0x01 # Port B data direction register. IPOLA = 0x02 IPOLB = 0x03 GPINTENA = 0x04 GPINTENB = 0x05 DEFVALA = 0x06 DEFVALB = 0x07 INTCONA = 0x08 INTCONB = 0x09 IOCON = 0x0A GPPUA = 0x0C GPPUB = 0x0D INTFA = 0x0E INTFB = 0x0F INTCAPA = 0x10 INTCAPB = 0x11 GPIOA = 0x12 # Port A data register. GPIOB = 0x13 # Port B data register. OLATA = 0x14 OLATB = 0x15 from machine import I2C # Initialize I2C bus i2c = I2C(I2CBUS, I2C.MASTER, baudrate=100000) # Configure all pins on Port A and B as outputs. i2c.writeto_mem (ADDRESS, IODIRA, bytes([0x00, 0x00])) # Send 0xf0 to Port A data register (GPIOA) i2c.writeto_mem (ADDRESS, GPIOA, bytes([0xf0])) # Clear all outputs and reset data direction bits. i2c.writeto_mem (ADDRESS, GPIOA, bytes([0x00,0x00])) i2c.writeto_mem (ADDRESS, IODIRA, bytes([0x00, 0x00])) I was going to post something slightly more useful, but had a hardware problem that has stopped me developing anything further for now (think it was just a broken jumper cable but I haven't had time to do any more yet).
  • Wipy2 non responsive
    wipy 2.0
    OK so heres what I have found. On one board it works if connected directly to 3.3v, the onboard regulater seems to be not working. The other board has the ChipPU pin pretty much low all the time -- about 400mv, goes to 0v when the button is pressed. putting a pullup on that pin doesn't help, it seems to be shorted. So that board is in permanent reset.
