• Visual Studio Code - Pymark - Download issue
  • Lopy4 not retry join request every 15 secs
    @fernandes-son That would be consistent with what I believe the code does. The AU915 region only sends join requests at SF12, which take a long time to send, and are thus affected by the specific duty cycle. Some other regions can use faster data rates which mitigates the issue, depending on what data rate is used first. Is there a specific reason this is an issue for you? Normally a device just joins once and after that it doesn't need to do it again, so it shouldn't be a big issue. You may try restricting data rates on the channels, but I wouldn't be surprised if the code actually enforced the DR0 rule for joins per the spec.
  • Visual studio code 1.43.0
    Don-iotD
    Thanks @pedroknup it works, but for some reason it has to be enabled manually over and over again.
  • Pytrack "dfu-util: Cannot set alt interface zero"
  • Core dump problem
    Dear @sita, @ps47 also experienced similar errors like you have been observing [1]. He is also using pure LoRa. Using the most recent 1.20.2.rc3 release seems to help here [2]. Thanks @husigeza and the whole Pycom team for mitigating this issue. I tried the new build LoPy4-1.20.2.rc3-0.8.0-vanilla-squirrel.tar.gz and not any “bad00bad bad00bad bad00bad” Core Panic happened till now. With kind regards, Andreas. [1] https://forum.pycom.io/topic/5514/random-core-panic-with-lora-socket-send-recv-device-doesnt-restart-try-with-config_esp32_panic_silent_reboot [2] https://community.hiveeyes.org/t/investigating-core-panics-on-the-lopy4/2878/29
  • Expansion Board 3.0 Serial Driver - doesn't exist
  • LoPy4 w/ PyTrack: GPS does not show up!
    gps pytrack
    @jcaron Thank you for answering. My question is not about WPS which is also a very interesting topic anyway or smartphones applications. My question is about GPS and L76 chipset as implemented on the PyTrack. Indeed WPS helps GPS to get quicker resolution. I do agree with you the PyTrack library is very crude, thank you for the last link, this one is helpful.
  • Pymakr 1.4.13 incompatible with Atom 1.38.2
    pymakr install atom settings
  • Atom/pymakr sync file types
    atom pymakr sync file type
    @goldfishalpha No, I just moved the txt-files outside the project folder. That is good enough for me. Johan
  • Lost PyMakr in VSCode
    vscode pymakr
    40
    7k Views
    @crumble and @Paul Thornton Switching on 'show hidden devices' in the Device manager (Windows 7) did not reveal anything new. Only COM1, Dell COM3 and Dell COM5 showed up (see screenprint in earlier post). What finally worked to solve my problem is to install the driver file pycom.inf downloaded from https://github.com/pycom/pycom-micropython-sigfox/blob/master/docs/pycom_esp32/tutorial/includes/downloads/pycom.inf from within the device manager (Action >> Add Legacy Hardware >> Search for and install the hardware automatically >> Ports (COM & LPT) >> Have disk >> Browse to pycom.inf file). I installed the 'Expansion 3' option. That installed the expansion board 3 driver, but it showed an error in the device manager (device cannot start). But when I next connected an expansion board V3.1 (with lopy4) to the laptop with usb, a new COM port ('Expansion 3 COM 19') appeared in the device manager, and this one allows me to connect from Atom. Also an Expansion board V2.1A with a lopy can now be connected. So problem solved. Although I still do not know what caused the connection problem. Auto connect does still not work because the working driver is at the bottom of the serial devices list, and the auto-connect takes the first one in the list, that one does not work. But anyway, PROBLEM SOLVED, I can connect manually by selecting the right COM port. Thanks for all the help!
  • Sipy deepsleep shield and sigfox transmission
    sipy voltage
    Hello @crasu if you use the pycom firmware tool and select "development" in the type dropdown on the communication page instead of "stable" you'll flash the latest release candidate that should have a fix for this.
  • Internet protocol login issues
    internet connec
    As in you have a pycom board at 192.168.1.20 that you'd like to connect to. Or are you having issues connecting to a wifi network via your pycom board?
  • FTP fails on larger files
    ftp
    Checked it with a second SD card with only one partition and rebootetd the router and clickt the LoRa antenna into the WiFi part. It is faster and I get less problems and sometimes larger files, but it will still breaks. Sometimes after a few megabytes sometime after a few k. At the moment it is only a nice to have feature. I wat to check the saved stream of the GPS in an editor before I use it as a test stream for my module. I will stop testing.
    Does this always fail on the same 3rd file? How large is that file? I presume its a normal .py file and not some multi MB binary or something equally strange?
  • Cannot install the Pycom Firmware Update
    win10 update tools
    @santorcuato Found a simple guide on how to add exceptions for programs. https://blog.avira.com/exceptions-avira-antivirus-3-steps/
  • Fresh install on VS Code: broken
    mac vscode pymakr
    @ulwur could you post your version numbers? (VSCode, Operating System, Pymakr)
  • Pycom Console not interactive on latest VSC/Pymakr
    pymakr console vsc
    luca.gammaL
    Hi @dan thanks for your reply. Actually not, also tried with an older VSC version (i.e. 1.25.1) but result is even worst (error: command pymakr.* not found and console doesn't start). Also downgraded Node.js to the LTS (8.12.0) but no luck. Because I'm using VSC for Python and to manage other non-pycom micropython-based boards via terminal it would be comfortable having a single IDE. Is there a particular setup known to work (firmware, VSC, Pymakr, Node.js, versions, platforms and architecture)? PS: Using Atom 1.31.1 on Win10/64 with Pymakr 1.4.4 I notice no issues, REPL responds correctly.
  • Lost pymakr Pycom console in VSCode after update VSCode
    pymakr vscode terminal
    @dan I have the same Issue on Ubuntu 18, extension don't work VSCode version 1.27.2 Pymakr version 1.0.2
  • Can't achieve to get a project in PyMakr
    pymakr problem project
    HI @ropito, I've tested it and I see that it indeed doesn't display the project name when working on windows. It's only a UI issue though. It does detect your project and will upload files from it when using the upload or download feature. It's just the UI label that doesn't display the name. I'll look into it and will fix the label in the next release.
