• Pymark plugin for VS Code
    pymakr
    @reader-uk Hello, Thanks for your help, nodejs was not installed, but vs code don't say it !
  • Pymakr console copy&paste on Mac
    pymakr console
  • Macos Sierra: Pycom firmware update crashes.
    firmware tool crash
  • FTP Upload and Sync Issue
    pymakr atom sync ftp upload
    @reefat as documented here: https://docs.pycom.io/chapter/toolsandfeatures/FTP.html There's a limit of 1 simultaneous connection, so you might have to tweak a few settings in Cyberduck or other FTP client. The described settings in FileZilla work very well.
  • Pymakr console should not be always up
    pymakr console
    @Ralph See how it looks after closing the console. The statusbar is gone. [image: 1501076575948-screen-shot-2017-07-26-at-9.41.56-am-resized.png]
  • Can't upload code in Atom. / Issues with Wi Fi Windows 10
    atom wi py 2.0
    @livius Update completed, issue still happening. I think I will do what you are doing. I also tried to install atom in my Linux PC (Debian wheezy), though it did not work, not so sure if it is because .deb is for Ubuntu, although it is a debian under the hood. Cheers Colombian1976
  • Connection to LoPy through Pysense fails
    pymakr pysense lopy serial
    A temporary fix: downgrade Pymakr Atom package from version 1.0.2 to version 1.0.1. Curious to know where the problem lies in version 1.0.2 for my LoPy-Pysense combo.
  • Serial Detection and Atom Pymakr debugging problems
    pymakr atom sipy serial debug
    Hi @adrien3d, Could you please try following the instructions at the bottom of this page, https://atom.io/packages/pymakr? It looks like you're having issues with the serial port module! Let me know if this helps, Alex
  • Is it just me or is Pycom sofware not very good?
    pymakr pymate issue atom
    @smssms I feel like I may be with you on this one I have yet to find a combination of H/W Firmware and tooling that is reliable. I wanna believe. It looks so promising and so close yet just not quite ready I think.
  • Project Sync works once after flash reset
    atom pymkr plugin lopy
    @amartinez Good to hear! @Andrea-Filippini Can you confirm if your problem was also solved with v1.0.0?
  • Pymakr error on sync
    pymakr sync err sync error esp8266 micorpython
    @Ralph Thanks a lot for your quick answer. i will keep going with rshell.
  • Problems to connect with Atom
    lopy atom connect
    @bucknall I' ve clean the file system and then I can connect to the board and sync (for example the traffic light example), but then, I cannot connect with the board anymore (this happens with the 3 boards): [image: 1494522587799-captura-resized.png]
  • Wrong url to OSX upgrader on downloads page
    upgrader
    Meanwhile I managed to find the dmg file here: https://software.pycom.io/downloads/pycom_update_1.1.1.b1.dmg
  • Why register to use Pymate?
    pymate issue
    Hi @stefan, You register to use Pymate as each instance of Pymate connects to our MQTT server which, in turn allows you to control your WiPy over WiFi. This requires us to add a lay of authentication to stop non-Pycom devices from taking resources from the server and use it for alternative means. Thanks, Alex
  • PyMakr on Mac OS X Snow Leopard?
    lopy pymakr mac snowleopard
    guyG
    @lollisoft Use Atom - the Pymakr standalone is deprecated. Make sure, before installing Atom, that you upgrade Node JS to latest stable release (if you're on older release you'll run in to some issues when installing the Pymakr plugin in Atom). Installing Node JS using homebrew - incase you don't have node installed Upgrading Node JS If you've not used Atom or Pymakr plugin before, see these docs first.
  • Updating fimrware on wipy fails with OSX 10.12.3
    firmware update wipy
    @robert-hh Since that was the problem in another discussion: Verify the the jumper is between GND and G23. G23 IS NOT P23. Internally, this is GPIO0, also tagged as P2. If the heartbeat LED is still flash after setting the jumper, you're not at the right port. [image: 1490693421335-index-resized.jpeg]
  • Pymakr starts but generates errors on each user action - Mac OS X
    pymakr lopy
    @fos no its not it is discontinued only future plugin https://forum.pycom.io/topic/635/pymakr-time-of-death-09-02
  • Pymakr under Linux Fedora. Anyone?
    @Avathar Pymakr is discontinued, see this for more info. https://forum.pycom.io/topic/635/pymakr-time-of-death-09-02/33
  • attributeError exception?
    Moved attributeerror exception pymakr
  • Pymate can't see router SSID
    Moved pymate issue ssid
